thebugmann
Aug 15, 2014Aspirant
Antenna Replacement
Is it possible to replace the antennas on the EX6100? I have tried with a little force to unscrew one but it does not seem to work. Other method?
Shadowlore
Aug 15, 2014Guide
that depends on if you're willing to void your warranty or not, tbh
Most of the external devices have antennae connectors inside of them on their system boards. Those antennae connectors can usually handle a directional yagi or something connected to them, but as always.. your mileage may vary.
If you're outside of your warranty period, you may consider at least opening up the device and looking.
