opelsin
Oct 12, 2021Follower
Any recommendation for a wifi range extender?
I need to extend the wifi in my home. I have 3 (small) floors and would like to have a signal on all floors. I have read some mixed reviews for this Netgear product on Amazon. Do you have a device you can recommend?
1 Reply
You didn't give us much to go off.
What actual size is the hope? 3 floors could be 1800sq ft or 10,000sq ft.
Size matters.
Also, what are the interior walls/floors made of as certain materials block wifi signal.
As well as if your looking at extenders or a mesh product.
We usually recommend an extender if you're only needing one. If you're needing one, I'd be leaning towards upgrading to a mesh system like Orbi or the MK nighthawk.
