Chiefs15's avatar
Chiefs15
AP using disabled guestnetwork's password
Trouble with AP picking up guest network (using guest networks password to sign onto AP wifi) -- when guest network shows disabled in genie.
Amped Pro AP connected to Netgear r6300v2 router.
Guest Network is disabled (per genie).
Yesterday I updated firmware on Netgear router.
on Genie I chose WPA2 for guest network security, prompted for password and entered it.
After these updates, went to sign on to wifi AP network and could not.
deleted AP wifi from computer and the signed on and AP could not recognize password.
Tried the new password I had entered for the Guest network on Netgear genie (Guest network still showing disabled) and that worked.  Why is my AP using the guest network's password?
Guest Network shows disabled in Netgear Genie
Overall, how do I make sure the AP is using my main network and not the guest network?
Netgear Genie shows Guest Network "DISABLED"
Thank you!
  • StephenB's avatar
    Chiefs15 wrote:
    Amped Pro AP
    Is this an AP (access point) or an extender?  Can you provide the actual model?
    • Chiefs15's avatar
      Chiefs15
      Amped Wireless AP600EX High Power Wireless-N 600mW Pro Access Point
      Using this with Amped Wireless SR600EX High Power Wireless-N 600mW ProSmart Repeater
      • StephenB's avatar
        Your question really isn't about the r6300v2.
        The AP600EX is either connected to the r6300v2 or the SR600EX over wired ethernet. Either way it won't be using wifi for backhaul.  If you want to isolate the wifi clients from each other, you'll need to find the wireless isolaton setting in the AP web UI.  I'm not seeing that feature in the AP600EX user guide, but it might be in the UI somewhere.
        The SR600EX can either be a extender or an AP.  If you are using it as an AP, then the same answer applies to it.  If you using it as an extender, then you tell the SR600EX what wireless network you want to extend in it's web ui.  So look there, and if its not set to your guest network then change it.
