mtutoot's avatar
mtutoot
Tutor
May 14, 2019
Attempting to use EX7000-100NAS as access point in detached garage
I am attempting to use a Nighthawk EX7000-100NAS AC1900 as an access point in a detached garage. The Wifi router is a Netgear WNDR4500 N900 and is located at the far end of the house from the garage....
  • plemans's avatar
    May 14, 2019
    In regards to the lan port usability. Here's a thread that addresses that. Basically the lan ports are still usable in AP mode.
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7000-as-Access-Point-LAN-port-still-usable/td-p/1056095
    How are you testing the cable? That's what I'd be looking at. If it works inside with a known good cable, it probably isn't the ex7000.  If you're only running 162ft, you should be good distance wise. So its checking for breaks, miswired ends, etc. I've accidentally nicked cables during stripping when I first started and have ended up troubleshooting for a while before seeing the small slice. Its not necessarily enough to fail a test but it was enough the data was corrupt during transmission.
