× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX7000 as Access Point - LAN port still usable ?
Geolem
Hello Guys,
By reading the User Manual before buying, I found something which annoying me...
On page 19 from the User Manual, I found :
In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection.
So... IF in Access Point mode, the 4 others LAN ports are not usable like a switch ?
Isn't it ?
Thanks for your time.
Message 1 of 5
Accepted Solutions
netwrks
Master
Re: EX7000 as Access Point - LAN port still usable ?
In Access Point, the LAN ports are usable.
Message 2 of 5
All Replies
netwrks
Master
Message 2 of 5
Geolem
Hello netwrks,
Purchase done (110€ at Amazon.fr).
Happy to come back on Netgear product.
Thanks again for your time, you have help me on a previous thread and finally choose this due to great discount.
Message 3 of 5
Geolem
Sad time... I just received it and it is an DAO 😞
Unfortunately, I came across a defective product at unpacking.
I wanted to set it up in Access Point mode, but it did not detect the DHCP server.
After I configure a static IP, I set the wifi but nothing happens, the web interface shows me that the channel 0 is assigned both 5Ghz 2.4Ghz that ... Of course, no PC or iPad, or Smartphone finds the SSID (configured yet broadcasted).
I performed the upgrade to the latest release. Same symptom.
I try to factory reset and put it in its simplest config. Still does not work.
I try as a repeater configuration, it does not detect wifi close (although a lot can be received).
So I think that the product is defective at the opening. Too bad, but it can happen.
I prefer not to continue the adventure with a replacement model.
Then Netgear does not work with DFS 5Ghz channels in Europe.
I put it in US region, I got more channels but still buggy.
So sad 😞
Amazon return.
Message 4 of 5
DarrenM
Sr. NETGEAR Moderator
Geolem
Sorry to hear the product was not working for you but if did decide to keep it the community is always here to help with issues.
DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5106 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
