Geolem
Feb 28, 2016Aspirant
EX7000 as Access Point - LAN port still usable ?
Hello Guys, By reading the User Manual before buying, I found something which annoying me... On page 19 from the User Manual, I found : In access point mode, you can connect your computer or...
- Feb 28, 2016
In Access Point, the LAN ports are usable.
netwrks
Feb 28, 2016Master
- GeolemFeb 29, 2016Aspirant
Hello netwrks,
Purchase done (110€ at Amazon.fr).
Happy to come back on Netgear product.
Thanks again for your time, you have help me on a previous thread and finally choose this due to great discount.
- GeolemMar 01, 2016Aspirant
Sad time... I just received it and it is an DAO :(
Unfortunately, I came across a defective product at unpacking.
I wanted to set it up in Access Point mode, but it did not detect the DHCP server.
After I configure a static IP, I set the wifi but nothing happens, the web interface shows me that the channel 0 is assigned both 5Ghz 2.4Ghz that ... Of course, no PC or iPad, or Smartphone finds the SSID (configured yet broadcasted).
I performed the upgrade to the latest release. Same symptom.
I try to factory reset and put it in its simplest config. Still does not work.
I try as a repeater configuration, it does not detect wifi close (although a lot can be received).So I think that the product is defective at the opening. Too bad, but it can happen.
I prefer not to continue the adventure with a replacement model.
Then Netgear does not work with DFS 5Ghz channels in Europe.I put it in US region, I got more channels but still buggy.
So sad :(
Amazon return.
- DarrenMMar 03, 2016Sr. NETGEAR Moderator
Geolem
Sorry to hear the product was not working for you but if did decide to keep it the community is always here to help with issues.
DarrenM
