access
2 TopicsEX7000 as Access Point - LAN port still usable ?
Hello Guys, By reading the User Manual before buying, I found something which annoying me... On page 19 from the User Manual, I found : In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection. So... IF in Access Point mode, the 4 others LAN ports are not usable like a switch ? Isn't it ? Thanks for your time.Solved5.6KViews0likes4Comments
