access
5 TopicsAdd Multiple Access Schedules
I am not sure how this is still NOT a fearure... Under Advanced>Security>Schedule, we should be able to setup multiple schedules for and it should even be per device. Currently, I can set only one schedule for all devices. This is very limiting compared to competing router options: D-Link, etc. I should be able to set MUTLIPLE access schedules on a per-device basis. For example, if I have two devices that I want to restrict when they can access the Internet, I should be able to state on device A it can access the Internet Sunday-Thursday from 4 pm - 10 pm and Friday-Saturday from 10 pm until 1 am. I should then be able to set a different schedule for device B, for example Sunday-Thursday from 6 pm - 11 pm and Friday-Saturday from 8 pm - 11 pm. How this feature wasn't implemented yesterday is beyond me???27KViews4likes16CommentsNo Drop Down Option in Genie for Remote Access
Hello, I am able on one of my computers at work to remorely access my router via the Genie app. I can also remotely access it via the iOS Genie app as well (Mac OS). On one computer in particular I can't and I do need access from this computer from time to time. The problem? I am not given the option to select Remote Acess from the dropdown (see attached). Thoughts?2KViews0likes4CommentsEX7000 as Access Point - LAN port still usable ?
Hello Guys, By reading the User Manual before buying, I found something which annoying me... On page 19 from the User Manual, I found : In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection. So... IF in Access Point mode, the 4 others LAN ports are not usable like a switch ? Isn't it ? Thanks for your time.Solved5.6KViews0likes4Comments
