RealisticDave
Oct 19, 2016Tutor
Authentication Problem When Trying To Connect
I have a Linksys router. Connected WN2000RPT as described in Netgear instructions. Everything went through fine, proper lights, -EXT is displayed on available networks scan, etc. Tried to connect a V...
- Oct 21, 2016
Hello RealisticDave
Have you made the SSID different on the router and not the same as the routers SSID?
DarrenM
DarrenM
Oct 21, 2016Sr. NETGEAR Moderator
Hello RealisticDave
DarrenM
RealisticDave
Oct 22, 2016Tutor
Darren, I tried this today. Got a pop-up when configuring the extender that Netgear doesn't recommend this, but I went ahead and did it anyway. (I understand the issue about having the same SSID to have your device follow the strongest signal, but if this is what it takes to have the router and extender play happy, so be it...) I've got all the devices that I wanted to connect to the extender looking good now, so it should be OK. Thanks again for your reply.
Cheers, Dave
