waymol
Dec 31, 2014Follower
Authentication Problem
I have connected EX6100
via WPS to my PC but cannot connect to extender Error message (Authentication Problem).
Any help gratefully recieved
1 Reply
- StevBelAspirant1. Did you put the EXTENDERS mac address into your ROUTERS wireless mac restricted list?
2. Are you in BOTH rangeS (2 TOP GREEN LIGHTS)?
3. ARE YOU USING A USB 2 PORT?
__ I THINK IT HELPS FOR RANGE __ IT DOES HELP FOR SPEED.
GET THE ROUTERS NETWORK NAME AND NUMBER AT THE ROUTER AND ENTER IT AT YOUR COMPUTER.
Network id name and number ARE case sensitive __ I think.
