Milt-Wood
May 26, 2017Tutor
Authentification problem
Is it possible to "overload" the AC750 EX6100 Extender? The Extender was purchased because my first Android Box(MXQ Pro) would not function on WiFi signal only. My Laptop functioned fine wit...
- May 31, 2017
Hello Darren,
No it was not necessary to try the reset. While trying and retrying to establish connection using the
Netgear password, I had an idea that maybe the problem was not between the Box and the Extender
but between the Extender and the Router. I entered the Network password and, voila, connection was
established.
In hindsight, maybe I should have realized the problem earlier, but there it was, a lesson learned.
Thanks to you, Darren, and the others who offered suggestions.
Regards Milt
DarrenM
May 31, 2017Sr. NETGEAR Moderator
Hello Milt-Wood
Did you try the factory reset?
DarrenM
Milt-Wood
May 31, 2017Tutor
Hello Darren,
established.
Regards Milt
- Milt-WoodMay 31, 2017Tutor
Sorry Darren, I miss spoke, The problem was between the Box and the Router not the Box and the Extender. Milt
