Milt-Wood's avatar
May 26, 2017
Authentification problem
    Is it possible to "overload" the AC750 EX6100 Extender?   The Extender was purchased because my first Android Box(MXQ Pro) would not  function on WiFi signal only. My Laptop functioned fine wit...
  • Milt-Wood's avatar
    Milt-Wood
    May 31, 2017
    Hello Darren,
       No it was not necessary to try the reset. While trying and retrying to establish connection using the
    Netgear password, I had an idea that maybe the problem was not between the Box and the Extender
    but between the Extender and the Router. I entered the Network password and, voila, connection was
    established.
      In hindsight, maybe I should have realized the problem earlier, but there it was, a lesson learned.
      Thanks to you, Darren, and the others who offered suggestions.
          Regards      Milt
