Jwoulfe
Oct 08, 2021Tutor
AX 1800 (EAX20) Extender log in connecting to the internet source router not the Mesh Extender
My AX1800 Mesh Extender (EAX20) log in process has recently been unable to connect either by the web or Nighthawk app. When trying to log into the extender with routerlogin.net, its trying to log into the internet source router and not the Extender. When using the Nighthawk app, the log in defaults to the internet source router not the Extender. When opeing the app, it keeps defaulting to the admin log in (Username and Password) which never works with my saved Extender's Username and Passord bescuase it keeps diecting to the internet source router.
Thoughts?
to log into the extender, either use its ip address or use mywifiext . net
If you log into the router, you should be able to get the IP address for the extender.
- JwoulfeTutor
Very good! That works fine. I guess the true issue must be the Nighthawk App. Not sure if this is the proper place for discussion but it seems the App, originally connects to the EAX20 extender and runs fine. Then after a while it switches to the internet source router and gets stuck there. I cannot get back to the EAX20.
Glad it works to use the IP address. Means device is working fine its just an app issue.
