Stupidchick99
Oct 07, 2024Follower
AX1800 WiFi Mesh Extender (EAX14 being hacked?
I've only started having difficulty with this priduct 3 months ago. When I first got it, it worked perfectly fine. I think it's being hacked into because my password for the login has been changed 2 times and I was unable to get it until I managed to change it again. The nighthawk app is saying it doesn't recognize my phone so I can't get in. Is this a matter of which phone I first set it up on? Also, the setting to autmoatically upgrade firmware had been set on no. I had it on yes. I think it's being hacked and if so, what can be done to effectively secure it? Btw. I'm not savvy in this area.
1 Reply
If you're concerned, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
