jdeady's avatar
jdeady
Follower
Dec 29, 2018
Backhaul still disconnect
Netgear you still have issues with the Mesh EX8000 backhaul which will disconnect from a R7000 at random, at that point no internet access is provided from the Mesh but the r7000 wireless works fine if you power the EX800 off, Netgear has updated the Mesh firmware from 1.0.1.164 to 1.0.1.180 and now 1.0.1.186 but connections issues have not stopped, the r7000 is using 1.0.9.60. I am currently looking and some other manufacturers options for a mesh network, the EX8000 is a wonderful concept but just does not work.
1 Reply
  • Same thing for me... I have tried everything.. every so often (and I do mean often) the 5g backhaul goes out and loses connection for 14 min. I really think it’s a software bug. I just can’t believe they haven’t gotten it right yet or fixed it. They keep pushing buggy firmwares.
    I have tried reverting back to 64 and 80 and even a test beta version but still the same results.
    Here is the issue I have. The 5G Broadcast a different channel for the 5G network. The 2.4 G network broadcast the same channel? Also why is there even a 2.4 G backhaul also? I have figured out that changing your router to not change the channel automatically definitely helps. But it seems like with a lot of congestion or whatever the case is the 5G backhaul just goes out randomly and it sucks.. the 2.4 G backhaul blows and it disconnects my Xbox temporary just long enough to kick me out of the game.
    I have been sent a new extender. Same results. It worked good for a couple weeks and then who knows what happened but same issue. And I do a hard factory reset every time I update or reflash the firmware. I attempt to only have my hardwire Xbox hooked up via LAN and disconnect and turn off the extenders WiFi but same results. I have given the extender QOS bandwidth and everything.
    I wish I could return the stupid thing but I can’t. I think my next step is going to run a cat 7 up in the attic over to the extender and use it as an access point.
    Hopefully my issues would then be resolved..
