edwin1993-_
Nov 19, 2018Aspirant
Blinking power
hi really need this help was working until i updated it then it started the power light to blink
Nov 19, 2018Guru - Experienced User
Do you mean the status LED?
Are you seeing the client WiFi network? Normally a blinking status LED means the device has been reset, so the client network might be named NETGEAR_EXT.
- edwin1993-_Nov 19, 2018Aspirant
no just the power led blinking nothing
- StephenBNov 19, 2018Guru - Experienced User
I suspect the firmware needs to be re-flashed. You might try sending DexterJB a private message (click on the envelope in the upper right of the forum pages), and ask if he can give you the procedure for that.
- edwin1993-_Nov 19, 2018AspirantOk I did that hopefully he response soon
