Smitht308
May 01, 2018Follower
Bought used how do i unlock it
Okay, Im using an old linksys 2.4 router its what have though. We bought this universal wifi range extender thinking it was a better router. well i tried to hook it up and i cannot use it because i dont know the login info. so where do i go from here is my question and dont say the store lol.
1 Reply
- DarrenMSr. NETGEAR Moderator
You will need to hold the reset button for 10+ seconds then the default login will be admin/password
DarrenM
