rboichat's avatar
rboichat
Brother MFC-L8650 keeps on disconnecting from wifi extender
Dear all,
  I am very puzzled, I have installed the wifi extender and renamed the extension (corpus) to a different name that the base wifi (wifihome).
However, my printer Brother keeps on disconnecting from this new wifi extension (corpus).
Is this because I use a different name that the base wifi?
Can you help?
Best
Romain
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rbouchat
    I would try to change the wireless channel on your router to see if the signal will be better and cause the drop to stop happening.
    DarrenM
    • rboichat's avatar
      rboichat
       Dear Darren,
        This seems like a very good idea thank you. However, I use the EX6150 AC 1200 and I can't see where I can change the wifi channel.
      Can you help me?
      Best
      Romain
