mcosper
Mar 15, 2018Follower
C3000
Can a NETGEAR AC1750 Smart WiFi Router—802.11ac Dual Band Gigabit (R6400) hook up to the netgear c3000 ?
trying to up my streaming but the nighthawk is a router only so am I able to use my router/modem combo with the nighthawk router?
1 Reply
- jvasanth1984Virtuoso
Hi mcosper,
Yes you can use C3000 with R6400. But its better to disable router mode on C3000 buy logging into it and disable it from administration option.
