JayG2's avatar
JayG2
C3700 5G band works at 200mbs but not 433mbps
Using EX3700 as an access point connected by ethernet to C3700 modem/router.   The EX3700 5g band seems to work if I set the EX3700 to 200mbs but not at 433mbs.  At the higher speed, it usually dpe...
  • TheEther's avatar
    TheEther
    Jul 20, 2016
    JayG2 wrote:
    Thanks, Darren.  Please let me know if you think I'm wrong, but I don't think your posting makes sense.  The EX3700 is connected to the C3700 by ethernet.  The EX3700 is configured as an access point.  I think the Wi-Fi speed of the C3700 is completely extraneous.  I only included that information because I'd like to know why 300mbs is not offered as an option on the EX3700.
    The EX3700 supports 802.11ac Wi-Fi.  The 433 Mbps setting uses a modulation scheme (256-QAM) in conjunction with an 80 MHz wide channel.  The 200 Mbps setting uses the same modulation scheme except with a 40 MHz wide channel.  There is no 300 Mbps setting because there is no corresponding modulation scheme.
    The C3700 supports 802.11n Wi-Fi.  300 Mbps uses 64-QAM with a 40 MHz channel.  AFAIK, there is no 200 Mbps setting.  It should be 145 Mbps (technically 144.4 Mbps).  This is 64-QAM with a 20 MHz channel.
