BrunoF
Jan 01, 2016Aspirant
Cable connection acces point N300wnr2000v3
Hello, I have my N300wnr2000v3 ingesteld als accespoint. Works great. But now I want a new connection by cable ethernet. The N300 does not regonised it. I have everything cable out, power cables off ...
- Jan 10, 2016
I searched and make work of teh suggestions, nothing helped. At last I bought a new cable and problem was solved. So, never trust the cable. Try by problems a other one of new one, may gives that good result.
I want to thank TheEther for all his help. I like it very much when people helping each other. Thanks!
TheEther
Jan 02, 2016Guru
Did your cable provider give you a pure modem or a combination router/modem? If it's the former, then you need to reconfigure your WNR2000v3 back to router mode.
- BrunoFJan 02, 2016Aspirant
The acces point is stable working in the network for internet. No problem. But I want to connect another device on internet and connect by the acces point. So, I want a extra device on internet by cable connect on the acces point.
