BrunoF
Jan 01, 2016Aspirant
Cable connection acces point N300wnr2000v3
Hello, I have my N300wnr2000v3 ingesteld als accespoint. Works great. But now I want a new connection by cable ethernet. The N300 does not regonised it. I have everything cable out, power cables off ...
- Jan 10, 2016
I searched and make work of teh suggestions, nothing helped. At last I bought a new cable and problem was solved. So, never trust the cable. Try by problems a other one of new one, may gives that good result.
I want to thank TheEther for all his help. I like it very much when people helping each other. Thanks!
TheEther
Jan 02, 2016Guru
Did your cable provider give you a pure modem or a combination router/modem? If it's the former, then you need to reconfigure your WNR2000v3 back to router mode.
BrunoF
Jan 02, 2016Aspirant
The acces point is stable working in the network for internet. No problem. But I want to connect another device on internet and connect by the acces point. So, I want a extra device on internet by cable connect on the acces point.
