um_chili
Jul 01, 2016Tutor
Cameras out of network range--Netgear range extender
Hi all, I have four Arlo cameras stationed around my house, and two of them are far enough from the router that they cannot get a signal. When I sync these cameras, a green square appears on my ...
TheEther
Jul 02, 2016Guru
You can configure the extender to broadcast the same SSID as the router. Or you can configure the cameras to connect to the extender's network.
um_chili
Jul 02, 2016Tutor
Great, those options sound very promising. How do you reconfigure the extender to broadcast a different SSID?
