Blanketyblank
Jun 15, 2018Aspirant
Can’t find netgear WiFi network
Just bought a new range extender and can’t find the netgear WiFi network - any suggestions please? I (have to set up manually too as no WPS...
Blanketyblank
This appears to be showing up as iinet network but it’s a secure network so I can’t connect? Have done factory reset on the extender but still shows the same... a.m. in Australia if that makes any difference...
- DexterJBJun 18, 2018NETGEAR Moderator
Hi Blanketyblank,
Welcome to the community!
1. Have you tried using another device (Android, iOS, tablet, laptop)?
2. Please make sure a proper factory reset is done. Page 34 of the user manual on this may link help out.
Dexter
Community Team
- DexterJBJun 21, 2018NETGEAR Moderator
Hi Blanketyblank,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
