Punkjazz021
Apr 01, 2020Aspirant
Can connect to extender, but not to router
Hey,
Been having some strange wifi issues lately. Noticing a lot since I'm working from home more often. Right now, I am able to connect to the internet through the wifi extender and it works perfectly fine, but I cannot connect to the internet through the actual router. Anyone ever had that or have ideas on how to fix it?
Thanks.
So your netgear extender is working great?
But you're unknown router isn't working?
What router is it?
- Punkjazz021Aspirant
That's correct. I should've included the router to begin with, sorry. Router is an Arris Surfboard SBG7600AC2. I use a 13" Macbook Pro.
You've said the extender works fine.
I hate to be dense but you're on a netgear forum asking why your arris router isn't working properly. Why aren't you asking Arris or their forum when they're the expert on their device?
