PKent
Apr 11, 2018Aspirant
Can I configure range extender to broadcast on different channel than router?
When I log on to mywifiext.net I see drop down arrows in the data boxes that display the channel which the extender is using to broadcast. However, the boxes are dim and there doesn't seem to be any...
DarrenM
Apr 13, 2018Sr. NETGEAR Moderator
Typically the extender follows the channel of the router so you wouldnt be able to change that.
DarrenM
PKent
Apr 13, 2018Aspirant
Thanks for the reply. However, what you're saying seems to contradict page 24 of my user's manual (in the section "Change the Basic WiFi Settings"), where it says, " 7. To change the wireless channel, select a number in the Channel list." See the attached screen capture file "capture.jpg." As I noted in my original post, the data box containing the channel number is grayed-out when I view my current settings. However, if the channel cannot be changed, why is there a drop-down arrow at the right edge of the data box that specifies which channel is being used?
