PF28's avatar
PF28
Can I have more than n300 connected to the same network?
I have an n300 WN3000 extender can I connect a 2nd to the same network?
  • A parallel setup should be OK i.e. both extenders communicating with the same base station, but daisy chaining i.e. base station – extender – extender typically provides very poor throughput at the distant end.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
  • Thanks Andy - very helpful.  Now tried it from teh same base and it works fine.
