DaleMcIn's avatar
DaleMcIn
Can I use 2 N300 extenders on the same network?
I think this has been asked/answered but wish to clarify.  I have a WNDR3700 router in my 'computer room' along with a N300 extender in my garage and it seems to work fine.  I would like to use a second EX2700/N300 extender in my media room that neither my router nor current extender will give good enough reception.  Can I use a second N300 extender in my media room as long as I change the SSID of this second extender? I assume the SSID name could be anything as long as it is different - am I correct there?
Thanks!
  • That's correct.  It is strongly recommended that each extender connect to the router's Wi-Fi network.  Do not piggy-back extenders.  The performance drop (as much as 75%) may not be acceptable.
    • DaleMcIn's avatar
      DaleMcIn
      Thank you.  I'd planned to attach each to the router individually in parallel and not to each other in series. Parallel should work though, right?
    • DaleMcIn's avatar
      DaleMcIn
      Thank you.  I have an R7000 router now conected to a 2500RP extender in the media room now. It's in "Internet Surfing Mode" with both 2.4 and 5GHz bands at the same time. I tried configuring it both Fastlane Technology modes but I can't get connected devices ot see it regardless of which mode I set it to. I would have thought the mode "Device-to-extender in 2.4GHz only and extender-to-router in 5GHz only mode would give better service than the combined modes but it has trouble connecting to the router in 5GHz mode even though the R7000 router is set to broadcast in both modes.
      • TheEther's avatar
        TheEther
        Guru
        5 GHz has less range than 2.4 GHz.  It's possible that the extender is too far from the R7000 to get a clean 5 GHz signal.
