zonomo's avatar
zonomo
Star
May 06, 2017
Can I use Multiple EX7000's
I have searched everywhere for this answer.   I have a Nighhalk routher downstairs, and an EX7000 upstairs.  Turns out I need an Etnernet port for a VOIP phone but running a cable from my router to my office isn't an option.  Can I just buy another EX7000 or does anyone have another recommendation?   Thank you.
  • Hello zonomo
    Yes you can use more than one extender just make sure to connect it to the main routers network and not the other extenders network.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello zonomo
    DarrenM
