patricials
Mar 20, 2021Follower
Can I use this with a Nighthawk AC1900 modem/router
Hello,
My ISP advised to get a third party router to improve connection. I have the Nighthawk AC1900 but it has not improved anything. I previously used a AC1900 range extender which did not do much (with the ISP own-router). Can I use both together and should that improve speed and range? Thanks
1 Reply
Way more info needed.
What actual models do you have? AC1900 is a speed and not a model number.
What size is your home?
What are the interior walls made of?
What gateway is it connected to?
