ssi112's avatar
ssi112
Can no longer connect to 5G network after firmware upgrade
I upgraded my Nighthawk X6 AC3200 to the latest firmware version: V1.0.4.28_10.1.54 Now I can no longer connect to my 5GEXT network. My laptop doesn't even show the network any longer. On m...
  • DarrenM's avatar
    Dec 19, 2018
    Have you tried to disable smart connect and rename the 5ghz network and see if the network shows back up?
    DarrenM
