fredand
Aug 04, 2017Aspirant
Can not extend my new AC-router
Hello guys! I just bought a new AC-router, tp-link Archer C9. Before I got a router from Technicolor. I used to extend my wifi with a netgear wn3000rp. But wiyh my new router the extende...
fredand
Aug 09, 2017Aspirant
Hello Darren, thanks for your answer. I tried what you said, twice acctually, but it is still the same. The extender has no problem to connect and extend my old router. But it can not stay connected and extend my new router.
All suggestions are welcome.
Best regards
Fredrik
Best regards
Fredrik
exxtreme76401
What security settings are you using? You device maybe older and not support the new encryption.
- fredandAug 09, 2017AspirantInteresting!
What parameter should I look for?
Hopefully they are named the same.
Best regards!
