isham
Nov 24, 2016Follower
can not set up range extendor
I am unable to set up my range extender and can not connect to www.mywifiext.net
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello isham
Try to factory reset the extender by holding the reset button for 10 seconds then try to connect via WPS or by going through the setup when connecting to the extender. Also make sure your router is using WPA2 security under the wireless settings of the router.
DarrenM
