Sonic1221
Apr 15, 2017Aspirant
Can the AC1750 serve as an extender?
Trying to set up an AC1750 as a range extender, can that be possible?
Sonic1221
Apr 16, 2017Aspirant
It's an R6400
TheEther
Apr 16, 2017Guru
The R6400 with stock firmware won't really work as an extender. If you are willing to install third-party firmware, then it will have support.
- pilot51Apr 18, 2017Guide
I'm trying to log into my AC1750 R6400 router so I can convert it into an access point. I'm doing this through the FIOS Modem/router that Frontier provided. Unfortunately, when I try to login to it through www.routerlogin.com or www.routerlogin.net, Netgear tells me:
You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
I cannot get into the Netgear router to change it's settings.
How can I bypass the Frontier modem/router? Even the entry to it is coax and mine is ethernet.
Thank you.
- TheEtherApr 18, 2017Guru
What is your goal? To use the R6400 as a router or as an Access Point?
- pilot51Apr 19, 2017Guide
I want to use the AC1750 R6400 as an Access Point, wired through a Powerline adapter that I have plugged in my bedroom.
The Frontier modem/router is on one end of the house, and my bedroom is about 150 feet diagonally on the other end of the house where I hardly get a wifi signal. The one thing Frontier FIOS told me, is that for some reason, it is not bridgeable.
In order to do that I connected the AC1750 to the Frontier modem/router via an ethernet cable and attempted to log into the AC1750 that I want to use as an access point, but I got the error message: You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
