Sonic1221
Apr 15, 2017Aspirant
Can the AC1750 serve as an extender?
Trying to set up an AC1750 as a range extender, can that be possible?
pilot51
Apr 22, 2017Guide
Unfortunately, when I turned off the wifi on the pc laptop, and entered 193.168.1.1 it still gave me the Frontier login. Then I turned off the wifi on the router and it told me it couldn't connect to 192.168.1.1
- TheEtherApr 22, 2017Guru
pilot51 wrote:
Unfortunately, when I turned off the wifi on the pc laptop, and entered 193.168.1.1 it still gave me the Frontier login. Then I turned off the wifi on the router and it told me it couldn't connect to 192.168.1.1It should not be possible to get a Frontier login if the R6400 and PC are physically connected to each other and nothing else. Is the PC getting an IP address from the R6400? You may want to factory reset the R6400 just to be sure it is running in router mode.
