lbellkna's avatar
lbellkna
Novice
Sep 06, 2013
Can you modify the _EXT name?
Good Morning,
I am new to the forums and hope I can word this question in a manner that everyone understands.
I was able to install my WiFi Booster for Mobile WN1000RP with limited problems. I used option 2, using my IPhone.
I now can see two networks one the regular name the other reg name + _EXT
both of which are correct.
The wifi via the original router is in the upper level of my house, (I have a three level split) the booster is in the middle level...all working well.
However two of my wi fi pieces of hardware (e.g. cell phone and tablet) I would like to be able to roam around the house.
I notice for instance that when using my tablet the best service is on the main level as that is where the booster is and it is picking up the _EXT network. But if I take it upstairs of course the signal is not as good because I am nearer the original router.
Is there a way to modify the wireless network name, so that the hardware simply uses one network and draws the strongest signal from where the I am standing? Again I hope I have not made this too complicated.
Thanking you in advance for your assistance. Lydia
  • You should able to login to extender GUI with browser and change the _ext SSID even of may give you some alert
  • Thank you for your assistance, but can you dummy it down a bit for me? I am totally unaware of what you are saying, but need a bit more information and perhaps steps. thanks again....Lydia
  • I appreciate your input, but can you please dummy it down a bit? More information and perhaps STEPS on how to? I am a bit of a novice, thanks again, Lydia
  • Make sure you are connected to the extender wirelessly, or via cable, and simply visit http://www.mywifiext.com/ alternatively http://www.mywifiext.net/. For all the wireless products you should be able to use "admin" and "password" to login if prompted for credentials. Then go to Setup > Wireless Settings and change the name in "Name (SSID)" and click "Apply". However, I would really advice you to contact NETGEAR for troubleshooting or further guidance. Have a look at Contact Support. :)
  • Use my.netgear.com portal to contact support
    You can download a manual at support.netgear.com. It will shows some of the steps that you need to do
