knguyen555
Apr 07, 2016Follower
Can you use 2 wifi extenders at the same time?
Can you use multiple wifi extenders?
Hello there, I just purchased a Wi-Fi extender 7000 and it works great downstairs but the signal is weak upstairs. My question is if I bought another wifi exten...
- Apr 08, 2016
Yes, you can use 2 extenders with a few caveats.
- Do not wirelessly connect one extender to another. Performance for the second extender will usually be unsatisfactory. Therefore, each extender should connect to the main router.
- Both extenders should not broadcast the same SSID as the main router. This is the default setting but many people often set up an extender to broadcast the same SSID to avoid programming devices with two separate SSIDs. You won't be able to do this with two extenders because there is a risk of them connecting to each other instead of the main router. This restriction doesn't apply if you are able to wire the extenders to the main router via Ethernet (or Powerline).
TheEther
Apr 08, 2016Guru
Gregory1234
Dec 29, 2017Initiate
Hey .. I has a simple qu on multiple (three units, on multi story villa) ACCESS POINTS (with these EX7000 Range Extenders with cables back to the master modem) .. when I set up each unit (EX7000) the Setup Wizard makes me enter a NEW ACCOUNT (email & pword).
Can I use the same one each time, or do I need to use 3 different emails??
Maybe I have to turn off the 1st Unit I setup & then setup & login to the next one separately (but with the same email ??)
