knguyen555
Apr 07, 2016Follower
Can you use 2 wifi extenders at the same time?
Can you use multiple wifi extenders?
Hello there, I just purchased a Wi-Fi extender 7000 and it works great downstairs but the signal is weak upstairs. My question is if I bought another wifi exten...
- Apr 08, 2016
Yes, you can use 2 extenders with a few caveats.
- Do not wirelessly connect one extender to another. Performance for the second extender will usually be unsatisfactory. Therefore, each extender should connect to the main router.
- Both extenders should not broadcast the same SSID as the main router. This is the default setting but many people often set up an extender to broadcast the same SSID to avoid programming devices with two separate SSIDs. You won't be able to do this with two extenders because there is a risk of them connecting to each other instead of the main router. This restriction doesn't apply if you are able to wire the extenders to the main router via Ethernet (or Powerline).
zoziano
Dec 04, 2018Guide
Yes, you can use 2 extenders with a few caveats. Do not wirelessly connect one extender to another. Performance for the second extender will usually be unsatisfactory. Therefore, each extender should connect to the main router.
- ihawkDec 04, 2018Tutor
You can, I have 3 extenders. 1 connected to the main 1 router and 2 daisy chained off with no loss of signal or traffic flow
- StephenBDec 05, 2018Guru - Experienced User
If you aren't using fastlane with a triband extender, then there will be a loss of throughput. However, your bottleneck might be your internet connection speed, and not your wifi.
- JimMaudMay 10, 2019Initiate
Hi.
I need some help to get this working properly.
I purchased two EX7500-100UKS and I can't get this to work as people are describing here.
I have a long house and the ISP modem router is at one end of the house and very poor wifi at the opposite side of the house.
I have the ISP modem-router (NowTV - 192.168.0.1 both 2 and 5 Ghz are broadcasting the same SSID) the DHCP is configured to allocate IP from 192.168.0.10 onwards.
I setup the first extender (EX7500_1) with fixed ip 192.168.0.2 and all is working well. I shut it off and configured the second extender (EX7500_2) with fixed ip 192.168.0.3 and again all is working well.
I moved EX7500_1 to a place in the middle of the house where the wifi connection to the NowTV router is still excellent to good and I moved the EX7500_2 to a place where the connection to the NowTV router is very poor but the connection to EX7500_1 is still excellent to good. However EX7500_2 always still makes a poor connection to NowTV rather than EX7500_1 which is by far the strongest connection.
For the EX7500_2 to connect to EX7500_1 it has to be moved completely out of range of NowTV, and in this spot the connection to EX75001 works but is poor (red led) on 2GHz and no connection on 5GHz.
So my question is why is it always making a poor connecting to the NowTV router rather than the stronger EX7500_1 extended network?
I setup both the EX7500 in the same spot close to the main router, with only the main router switched on, before moving them, I used the smart setup feature in the browser. I can see in the connected devices page that EX7500_2 only connects to EX7500_1 when it is completely out of range of NowTV, but I cannot work out how to resolve it.
Thank you.
