Casey1992
Dec 29, 2016Aspirant
Canged providers WN300RPv3
I have changed internet providers and I can't get the extender to work. I've reset many times too. please help. Now the green light will blink , I push the WPS button on the router and then the ...
- Jan 16, 2017
Just need to connect it to the extender then go to www.mywifiext.net in a web browser then it should let you manually connect the extender to the router.
DarrenM
DarrenM
Jan 04, 2017Sr. NETGEAR Moderator
Hello casey1992
Bring the extender into the same room as the new router hold down the reset button for 10 seconds or longer to make sure it has done a factory reset. Then try to do the setup again.
DarrenM
- Casey1992Jan 11, 2017Aspirant
Thank you for trying to help. I did press the button for at least 10 sec. Then I followed the instructions by pressing the WPS button on the extender and then on my router. The button on the extender blinked for a while then nothing.
- DarrenMJan 11, 2017Sr. NETGEAR Moderator
Hello Casey1992
Have you tried to use the manual setup by connecting to the extenders wireless then going to www.mywifiext.net and then go through the setup wizard.
DarrenM
Thanks, yes I have I get this message YOU ARE NOT CONNECTED TO YOUR EXTENDER’S WIFI NETWORK. PLEASE CHECK YOUR CURRENT CONNECTION AND TRY AGAIN.
I appreciate your help.
