Casey1992
Dec 29, 2016Aspirant
Canged providers WN300RPv3
I have changed internet providers and I can't get the extender to work. I've reset many times too. please help. Now the green light will blink , I push the WPS button on the router and then the ...
- Jan 16, 2017
Just need to connect it to the extender then go to www.mywifiext.net in a web browser then it should let you manually connect the extender to the router.
DarrenM
DarrenM
Jan 11, 2017Sr. NETGEAR Moderator
Hello Casey1992
Have you tried to use the manual setup by connecting to the extenders wireless then going to www.mywifiext.net and then go through the setup wizard.
DarrenM
Casey1992
Jan 11, 2017Aspirant
Thanks, yes I have I get this message YOU ARE NOT CONNECTED TO YOUR EXTENDER’S WIFI NETWORK. PLEASE CHECK YOUR CURRENT CONNECTION AND TRY AGAIN.
I appreciate your help.
- DarrenMJan 11, 2017Sr. NETGEAR Moderator
Hello Casey1992
You can connect to the extender via Ethernet directly to the unit in order to get to the settings.
DarrenM
- Casey1992Jan 13, 2017Aspirant
I have an ethernet cord. So I will plug it into the Netgear and then to my modem or router? Then do I push the wps button? I so appreciate your patience with me. Thanks so much!
- DarrenMJan 16, 2017Sr. NETGEAR Moderator
DarrenM
