Casey1992
Dec 29, 2016Aspirant
Canged providers WN300RPv3
I have changed internet providers and I can't get the extender to work. I've reset many times too. please help. Now the green light will blink , I push the WPS button on the router and then the ...
- Jan 16, 2017
Just need to connect it to the extender then go to www.mywifiext.net in a web browser then it should let you manually connect the extender to the router.
DarrenM
Casey1992
Jan 13, 2017Aspirant
I have an ethernet cord. So I will plug it into the Netgear and then to my modem or router? Then do I push the wps button? I so appreciate your patience with me. Thanks so much!
DarrenM
Jan 16, 2017Sr. NETGEAR Moderator
DarrenM
- Casey1992Jan 18, 2017Aspirant
Thank you DarrenM for all of your help. I finally got it to work. Thanks for sticking by me! PHEW! THANK YOU THANK YOU THANK YOU!
