lnrharveaux
Jan 19, 2016Aspirant
cannot access www.routerlogin using .net or .com
Have a 2Wire Gateway model 2701HG connected to netgear AC1900 R7000. Cannot access routerlogin either .com or .net. Was able to download netgear genie which sees my wifi. However on router setting pa...
- Jan 19, 2016
I would connect by ethernet cable to your R7000 using a laptop / pc, then browse to:
You should be able to access the setup wizard from there
lnrharveaux
Thank you. Am now connected
