danaldo's avatar
danaldo
Cannot change WiFi speed with WN3000 Range Extende
Hi all,
I try to change the WiFi speed after having succesfully connected to the original WiFi network and extending it with the WN3000. But the dropdown list is blocked. When I connect to the original WiFi network directly the speed is up to 300 Mbit, that is why I thought I could also change in the extender.
Any idea?
Thanks!
Daniel
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello danaldo
    Are you on the latest firmware if not what version are you using?
    DarrenM
    • danaldo's avatar
      danaldo
      Yes, :
      • Hardware Version: WN3000RPv3
      • Firmware Version: V1.0.2.24
      • DarrenM's avatar
        DarrenM
        Hello danaldo
        Have you tried to use a different web browser when trying to change this setting?
        DarrenM
