Promotor
Mar 16, 2018Aspirant
cannot conect to the internet but not on every device
Hi, I was reading a lot of topics with similar issue but nothing help me to fix my issue. I have EX6200 and the problem is that device which was connected and had internet acces befere, now don't hav...
jvasanth1984
Mar 16, 2018Virtuoso
Hi Promotor,
Who is your internet provider and what is the router to which you have configured the extender? What is the IP you are getting on working device and how about on non-working device at the same instance?
- PromotorMar 17, 2018Aspirant
My PC which is not connected - but was connected before. Now i'm getting message from troubleshooter "Wi-Fi" doesn't have viald IP configuration. ISP: NextGenTel AS
Windows IP Configuration
Ethernet adapter Ethernet:Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :Wireless LAN adapter Local Area Connection* 2:
Connection-specific DNS Suffix . :Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::fd7c:4f31:312c:2224%16
Autoconfiguration IPv4 Address. . : 169.254.34.36
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :Tunnel adapter Local Area Connection* 12:
Connection-specific DNS Suffix . :Second PC which is arleady connected:
Wireless LAN adapter Połączenie lokalne* 2:
Connection-specific DNS Suffix . : lan
Link-local IPv6 Address . . . . . : fe80::1aa:c033:92:ca16%13
IPv4 Address. . . . . . . . . . . : 10.0.0.129
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.1
Wireless LAN adapter Połączenie lokalne* 11:
Link-local IPv6 Address . . . . . : fe80::90f8:1885:325f:569a%35
IPv4 Address. . . . . . . . . . . : 192.168.137.1
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:8f7:2dcd:a56a:f235
Link-local IPv6 Address . . . . . : fe80::8f7:2dcd:a56a:f235%8
Default Gateway . . . . . . . . . : ::- jvasanth1984Mar 17, 2018Virtuoso
Hi Promotor,
Try modifying wireless channel on your router and see if that helps.
