AKD
Jun 02, 2016Aspirant
Cannot connect past "obtaining an IP address"
EX2700 n300 - Started getting cannot "obtaining ip address..." and will not connect. Can only connect on one Windows 10 laptop. Cannot get the IP to connect on android phone, android tablets, Macboo...
- Jun 10, 2016
I believe it is my router, not the extender. Will be replacing the router.
DarrenM
Jun 09, 2016Sr. NETGEAR Moderator
Hello AKD
Have you tried to change the security type on the extender or the wireless channel? also you may want to do a factory reset and go through the extender setup again.
DarrenM
AKD
Jun 10, 2016Aspirant
