Chrispies66
Apr 26, 2018Aspirant
cannot connect to 5ghz on ex6130 extender
Hi,
During setup ok to connect to 2.4GHz but will not connect to 5GHz,? Says internet not available.
DarrenM
May 01, 2018Sr. NETGEAR Moderator
What router are you trying to connect the extender to?
DarrenM
- Chrispies66May 02, 2018Aspirant
It's is a talktalk super router dual band
- DarrenMMay 03, 2018Sr. NETGEAR Moderator
You may want to change the wireless channel of the 5ghz network on the talk talk also make sure it is using WPA2 security then try connecting the extender to the router again.
DarrenM
