shaase5
Apr 22, 2020Aspirant
Cannot connect to Extender network - EX6150|AC1200
On my Android phone, in the WiFi Network settings I can see the two networks I set up on the Extender (2G and 5G). When I try to connect to either one of them, I see on the Extender a green connecti...
Apr 22, 2020Guru - Experienced User
check this:
They recommend enabling mac filtering through the router
dackakarot
plemans wrote:check this:
Did that already when I first set up this router. Also I did a reset on the main router to see if that would help. Everything is on WPA2, no weird characters in SSIDs or passwords. I also don't understand why any of it would have changed, since it worked great for a year; we haven't changed anything or moved anything in that time.
- plemansApr 22, 2020Guru - Experienced User
Is it set in extender mode on the switch?
Have you tried running it in access point mode to see if it works that route?
- dackakarotApr 22, 2020Aspirant
Yes, it's on extender.
No, it did not work on access point.
In extender mode it needs to be hardwired into the router.
If it doesn't work in extender mode or AP mode, and you've tried reloading firmware, then you probably might have a bad unit.
