shaase5
Apr 22, 2020Aspirant
Cannot connect to Extender network - EX6150|AC1200
On my Android phone, in the WiFi Network settings I can see the two networks I set up on the Extender (2G and 5G). When I try to connect to either one of them, I see on the Extender a green connecti...
Apr 22, 2020Guru - Experienced User
Is it set in extender mode on the switch?
Have you tried running it in access point mode to see if it works that route?
dackakarot
Yes, it's on extender.
No, it did not work on access point.
- plemansApr 22, 2020Guru - Experienced User
In extender mode it needs to be hardwired into the router.
If it doesn't work in extender mode or AP mode, and you've tried reloading firmware, then you probably might have a bad unit.
- dackakarotApr 22, 2020Aspirant
In extender it needs to be hardwired to the router? It never was before. I thought it had to be hard wired to the router in access point mode
sorry,
Hardwired in access point mode
