shaase5
Apr 22, 2020Aspirant
Cannot connect to Extender network - EX6150|AC1200
On my Android phone, in the WiFi Network settings I can see the two networks I set up on the Extender (2G and 5G). When I try to connect to either one of them, I see on the Extender a green connecti...
Apr 23, 2020Guru - Experienced User
shaase5 wrote:In the instructions for enabling Mac filtering, it says to add your Wifi device/s to the extender's network and then go to an online site on that device to login into the extender (while using the extender's network). Ironically, you can't go to that online address because you have no internet while using the extender's network, which is what you are trying to fix. So it's basically impossible.
Are you talking about the instructions for your router mac filtering?
If so, just connect to the router and do it.
shaase5
Apr 23, 2020Aspirant
In the Extender's user manual, 2 of the steps that describe how to get the MAC addresses that you need to add to the router.are as follows:
7. Scroll down and select Connected Devices.
The Connected Devices section displays the MAC addresses and virtual MAC addresses
for computer and WiFi devices that are connected to the extender network.
8. On the router, add all of the virtual MAC addresses from your extender to your router’s MAC
filter table.
I can't login to the extender to get those addresses because I can't get onto the internet with a device that is on the extender's network. It's a Catch22. You need to get on the internet to login to the extender with a device that's on the extender's network (so that you can get those MAC addresses), yet I can't get on the extender's network to login as that is the problem I am trying to fix (not getting an internet connection).
- plemansApr 23, 2020Guru - Experienced User
You don't need to get online to get those addresses.
all you need is the IP address for the extender.
that should be in the router's attached devices list (or whatever your router uses)
- dackakarotApr 23, 2020Aspirant
To update my story. Powered down my main Asus router for 10 min again, plugged it back in, then plugged in extender, and everything magically reconnected. Not sure why this didn't work the first time.
