shaase5
Apr 22, 2020Aspirant
Cannot connect to Extender network - EX6150|AC1200
On my Android phone, in the WiFi Network settings I can see the two networks I set up on the Extender (2G and 5G). When I try to connect to either one of them, I see on the Extender a green connecti...
Apr 23, 2020Guru - Experienced User
You don't need to get online to get those addresses.
all you need is the IP address for the extender.
that should be in the router's attached devices list (or whatever your router uses)
dackakarot
Apr 23, 2020Aspirant
To update my story. Powered down my main Asus router for 10 min again, plugged it back in, then plugged in extender, and everything magically reconnected. Not sure why this didn't work the first time.
